Home > Technical (L322) > Brake pipe help/advice
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
Hi all in the middle of trying to replace osf brake pipe corroded at flexi end and wondering if
It’s possible or even safe to cut away the rusted part and make a new join further up think it’s the original steel pipe which all looks good (looks impossible to get to replace to be honest)
Cheers
Post #569504 11th Oct 2020 2:24pm
No reason at all why not provided you can get onto as new pipe. Thumbs Up
Post #569527 11th Oct 2020 5:54pm
Jack last
Cheers rest is fine just bottom part is rusted waiting on flexi being delivered
Post #569533 11th Oct 2020 6:13pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
I recently replaced all pipes with OEM ones. Can't say I encountered any problems during the install,and genuine LR pipes are cheap.
Just dropped the rear subframe a bit to pull the pipes through. 2007 L322 3.6 TDV8 Stornoway
Post #569624 12th Oct 2020 1:04pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Re: Brake pipe help/advice
Cheers
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #569792 14th Oct 2020 8:34am
