Irrespective of the wheel type, as you cannot have them diamond finished again, you have two choices:
1. Paint and clear lacquer over the top
2. Powder coat
Powder coat is viewed as more hard wearing initially. However, this is a topic of debate. Powder coat never actually adheres to the surface of the wheel, unlike paint. Instead, it just covers it. This means that the slightest of nick or chip through replacing tyres, stones or kerb damage, will mean that the powder coat surface is comprised. Once the surface has compromised, water can make it's way behind the powder coat and it will start blowing up and peeling off.
That said, I've had powder coated wheels previously and have experienced no problems, probably due to keeping them in pristine condition. Knowing what I know now though, I would always opt for a painted finish with a clear 2k lacquer over the top.
Note that wheel manufacturers never powder coat and always use a combination of paint and lacquer, except for diamond turned wheels of course!
Note that the silver used on Land Rover vehicles is 'Sparkle Silver' with paint code NMH if you decide to go that route.
Hope this helps Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
