Home > Technical (L322) > FBH issues |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
How's about filling in your model and year in the profile? Helps all of us help you better.
4th Oct 2020 2:38pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Check to see if the timer has been set on timed climate on the central display. It’s a possibility.
4th Oct 2020 2:46pm |
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 |
Sorry, it’s an early 2007 TDV8 Vogue I will put it in my profile.
4th Oct 2020 3:24pm |
It seems odd that it's runningif you haven't used the remote and the timed climate is off. Not sure of the fuse being out will reset the FBH but it shouldn't do any harm. There's the workshop manual in the wiki that may cover your FF (2007/2010) and the FBH can be found about page 2090. That may give you an idication of how it should work. Also in the 2011/13 WM there's a good write up in
4th Oct 2020 4:16pm |
Thanks for your help , I might try pairing the remote and turning it off, no idea how to pair it though but will search on here. |
4th Oct 2020 5:05pm |
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 |
The sign to tell if it is working or not is to listen for the FBH fuel pump. If you cannot hear that pulsing the FBH is not working. 2004 4.2 SC Japan Spec
4th Oct 2020 5:14pm |
I can hear what sounds like the fan for the FBH in the near side wheel arch but it seems to turn itself off after a minute or two and there is no smoke and no heat, guess the FBH isn’t working or getting fuel?. |
4th Oct 2020 5:55pm |
If you can’t hear the fuel pump ticking then it hasn’t ignited. As I said the noise comes from the rear
4th Oct 2020 6:06pm |
triphase Member Since: 21 Sep 2020 Location: Northeast USA Posts: 6 |
It looks at ambient temperature and will enter parked ventilation mode if the ambient temperature is high (fans will run, but FBH will not ignite). If memory serves, I believe the threshold is 60F. I'm not super familiar with MY07, but on MY10-MY12, the two different LED's on the "Auto" button on the climate module will blink at 2hz to indicate the current FBH status (parked heating vs parked ventilation mode being commanded).
8th Oct 2020 8:35pm |
