Home > General > RAVE no work
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Unnecessary quote removed
@mjdronfield
You are running version 1903 which has been superseded by version 1909 in spring this year .
Version 2004 is where this problem arises. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #570985 26th Oct 2020 11:41am
mjdronfield
Ah, ok.
Not sure why mine hasn’t updated then.
Perhaps the PATH variable can be updated so it looks for Adobe in the RAVE folder first, but the it would try and use that for all PDFs. Maybe need a script to save old path, mod it, run rave then change PATH back after.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #570986 26th Oct 2020 11:47am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
The latest version of Windows 10 is the October 2020 Update, version “20H2,” which was released on October 20, 2020. 2011 TDV8 Vogue SE
Post #570987 26th Oct 2020 11:50am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #570988 26th Oct 2020 11:54am
bigbo
Thumbs Up to both the above. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #570990 26th Oct 2020 11:59am
bigbo
I have just installed W10 v2004 on my Desktop which I don't use very much these days.
Strangely Rave for both Land Rover and MG works just fine.
So I have 3 laptops that wont run Rave and one Desktop that will.
One of those laptops is running the insider preview version of windows 10 so I will try a clean install on that in the next week or two to see if I can get it working. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #571039 26th Oct 2020 11:03pm
mjdronfield
I don’t actually need RAVE, having a 2011 car, but I find it easier to use than the workshop manual in the wiki, as each bit is a separate pdf. The RAVE menu system is good.
I like a bit of a challenge, been in IT all my life, but not as techy as I once was, so a bit out of touch with the behind the scenes of Windows 10.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571040 26th Oct 2020 11:09pm
bigbo
I like Rave, it works well and in my opinion better than say VW's similar system.
I have been trying to convert the later model PDF to Word so that I can edit all the links so they point to the local document and not Topix but without success as they are password protected.
I too have been in IT for most of my life and am now retired so its very difficult to keep up, hence being a part of the Insider program.
Getting a new Knee fitted on Thursday so will have a good look at this while I recover and get back on my feet. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #571041 27th Oct 2020 1:39am
bigbo
OK got bored today as I am in isolation, and have had another look.
If you want to use Rave then you need to change the compatibility to Windows 98 / ME.
Just right click on your shortcut and click properties, then click the compatibility tab, click "run the program in compatibility mode" and then select Windows 98 / ME
I went through all the options and this one worked.
David
Edit : This may be related to using Windows 10 Home, I do not have the problem on Windows 10 Pro but I don't have enough data to go on. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #571098 27th Oct 2020 7:18pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
I tried it in compatability mode with Win 98 and it still didnt load.
I have the 1st version of Win 2004. Big Cry
Bigbo,
You have new PM
Post #571109 27th Oct 2020 10:56pm
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
rave
Hi Bigbo,
any chance to get a copy of rave?
BR
Post #590908 11th Apr 2021 4:53pm
mjdronfield
It’s available for download in the Wiki..... top right, under the fullfatrr banner.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #590909 11th Apr 2021 4:56pm
hbthepilot
thank you Thumbs Up
Post #590960 12th Apr 2021 5:46am
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Thanks Bigbo for the tip on changing the compatability properties to Windows 98/ME, now works a treat. Been bugging for months not being able to get access. Thumbs Up David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #591203 14th Apr 2021 10:52am
