Home > Maintenance & Mods (L322) > Where to start (Trans failsafe program)?
kjmeijer
Netherlands 2011 Range Rover Supercharged 5.0 SC V8 Buckingham Blue
My 2005 4.4 V8 (63.000 km’s) started to give the Trans failsafe program message (and also goes in that mode) some months ago and now it’s becoming worse: almost every day I get one or more of these messages. After restarting it is away for some time.
I first exchanged the battery but no improvement. I also had the gearbox flushed. When I clear all faults the message looks to be away for a few days.
My LR specialist had a look at it and says he can start changing parts (starting with the potentiometer) but no guarantees on where this ends.
Any ideas here on where to start best without making to many unnecessary expences?
The codes:
 2011 RR 5.0 SC & 2021 New Defender D300
Post #568253 28th Sep 2020 10:42am
Dolphinboy
RRphil on this forum is GOD on this gearbox (he had his own repair and manufacture workshop. There is nothing he doesn't know about this. He wont take PMs so leave it up for him to see.]
PS RRPhil we miss you Big Cry Big Cry Bow down
Post #568288 28th Sep 2020 3:15pm
Gsxr1250dave
Gearbox flush without the oil cooler being change is a bit pointless as the oil cooler blocks up, also replace your radiator.
Post #568299 28th Sep 2020 5:43pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Gearbox Switch Fault : General Fault often relates to the Park Inhibit switch on the side of the gearbox.
I have the same issue with mine at the moment which is a repeat of the same fault I had about 10 years ago which a new switch fixed.
Anyway check out this thread regarding testing the Inhibit switch:
https://www.fullfatrr.com/forum/topic15665.html
Post #568403 29th Sep 2020 9:57pm
