Home > Technical (L322) > Delay when selecting reverse
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
I noticed today that there was a delay of 1-2 seconds when selecting reverse gear. The car was up to normal temperature and is well serviced.
Is this normal?
Jim
Post #568160 27th Sep 2020 6:10pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I've got this. Sometimes does the same thing in 1st.
First thing to check is ATF fluid level. Might be a bit low. I'm suspicious of cracked mechatronic sleeves.
Post #568170 27th Sep 2020 7:38pm
jim4244
Hmmmmm...... worrying eh?
Jim
Post #568277 28th Sep 2020 12:55pm
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
I have the same issue with my disco 2 although it's more noticeable from cold usually its a case of giving it a few more rev's, I'm not an expert but I wonder if its just something to do with the way the gear box/torque convertor works especially as I'm on top of replacing gear box fluid etc. since mine failed and had to be completely rebuilt.
Post #568445 30th Sep 2020 3:52pm
