Home > In Car Electronics (L322) > 2011 logic 7 main drivers speaker
t5pete
Hello all,
I've currently got an issue with the main lower speaker in the drivers door.
I've inspected and looks like the cone at the rear has separated and not accessible to fix.
So the main question is do I replace with a second hand unit or do land rover still sell them?
Picture of speaker required
Thank you
Post #568143 27th Sep 2020 3:47pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
E bay is your friend,got a brand new genuine for 50 quid odd a couple of weeks ago
Post #568146 27th Sep 2020 4:18pm
t5pete
Just purchased one thank you for the head up.
Post #568147 27th Sep 2020 4:21pm
JoolsB
Get yourself some new clips for the door cards too, you’re bound to lose/snap a couple in the process.
Post #568175 27th Sep 2020 7:48pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Re: 2011 logic 7 main drivers speaker
t5pete wrote:
Hello all,
Wow, this is spooky, I just worked out this evening that I have the exact same problem! Noticed on certain bits of music there's a little bit of a crackle/bang from the bass speaker on the right hand side, exactly the same!
I saw new speakers for ~50quid on LRParts.net, with the part number: XQM500420
Post #568310 28th Sep 2020 7:38pm
t5pete
Ours was quite bad with most music, hopefully the speaker will be delivered tomorrow so will get that fitted
Post #568315 28th Sep 2020 7:54pm
JoolsB
It must be a common fault, the one I replaced was a replacement rather than the original!
Post #568436 30th Sep 2020 2:22pm
triphase
United States 2010 Range Rover HSE 5.0 V8 Alaska White
PM me if you need these
Post #569253 8th Oct 2020 8:44pm
