Home > Maintenance & Mods (L322) > Drop Links |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
You're correct about the rears - definitely a wheel off job.
27th Sep 2020 11:06am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
Did mine last weekend, much easier with the wheels off. Personally I wouldn’t attempt it with the wheels on.
27th Sep 2020 11:42am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 283 |
Wheels off it is then, thanks gents.
27th Sep 2020 1:34pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
I did my front drop links with the wheels on. Didn't take much more than 15 mins from memory. |
27th Sep 2020 7:40pm |
I’m just thinking that there would be less tension on them with the wheels on the ground.
27th Sep 2020 7:46pm |
To have no tension on the ARB, you need both front wheels on the ground, or both in the air. |
27th Sep 2020 7:49pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Done them a few times now with both the wheels on and the wheels off. Found wheels on is fine if the nuts are not rusted up. If that nuts are rusted, would suggest wheels off so you can get in with and angle grinder 56 TDV8 Vogue SE
27th Sep 2020 7:58pm |
Well after 10 weeks away, I finally got round to it today.
19th Dec 2020 3:55pm |
