Home > Technical (L405) > Windscreen washers, Air con and brake vibration
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
A few questions.
Can you adjust washer jets, as mine mostly spray under the bonnet.
Air Con. keep having to turn to LOW as 16 just doesn’t keep me cool
Brake vibration. I think my discs are warped, but just been told no longer a warranty issue as it’s termed wear and tear! I’ve done 20k, does this seem right?
Post #567992 25th Sep 2020 2:16pm
washer jets now have a very fine spray so i can imagine that the spray holes are very small and not as big as the older ones that you could put a needle in and re-direct..its worth a try though..
frustrating that you cant select any thing lower than 16 without the a/c coming on..
as for the brakes , it depends when they were fitted and when they started to vibrate... ... - .- -.
Post #567993 25th Sep 2020 2:25pm
