Home > Technical (L405) > New owner, over boost error code and DPF question |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
If I was you, I would throw it back at them to fix... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Sep 2020 7:52pm |
GY Member Since: 15 Sep 2020 Location: Buckinghamshire Posts: 10 |
Agreed. Was told the first thing they would try was running a few miles with premium fuel and a bottle of turbo cleaner. Thought I could do that bit myself.
24th Sep 2020 12:58pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3162 |
The car will not regen with a red light. AFAIK the only way is for a garage to use their software and reset the parameters to make it go. LR charge around £90 for this. |
24th Sep 2020 2:14pm |
Just take it back. I suspect either an intake leak or it’s been used for too many short journeys. For them to fix, not you. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Sep 2020 3:20pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
As above, it’s for the supplying garage to resolve, the information they are giving at the moment sounds more like a way to keep you from bringing it back. Red DPF full warning cannot always be rectified by a forced diagnostics regeneration request, both Dr Rob and I have both had to have the DPF removed and cleaned to clear the Red warning (L322 model but principal is the same). Take the time to look up your consumer rights as it used to be that you had to give the supplying garage 1 chance to rectify any issues before you could reject the car. Most additives such as DPF cleaner, EGR cleaner, injector cleaner etc that your pour in tank do absolutely nothing other than to help empty your wallet. 2011 TDV8 Vogue SE |
24th Sep 2020 4:41pm |
Thanks guys. Good to hear your experienced thoughts.
24th Sep 2020 4:52pm |
For the record, mine has not been removed / cleaned. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
25th Sep 2020 2:12pm |
Leave it with them until they prove its fixed and ask for a detailed analysis of their findings. I would expect them to start with a HIGH pressure smoke test for any intake leaks as a bare minimum. The statement around expensive diesel is If it does not get resolved, hand it back and take the cash Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
25th Sep 2020 2:15pm |
Thank you |
25th Sep 2020 3:11pm |
also get them to do a DPF pressure test. If the DPF IS filling up, it will have a psi of 15 or so. Mine was 2psi (therefore empty) but the car still tried to regen as the sensors' parameters were incorrectly set. This is an easy and cheap way to check your physical DPF levels |
25th Sep 2020 3:31pm |
Apologies DrRob it should have stated that GDDR and I have had this done 2011 TDV8 Vogue SE |
27th Sep 2020 3:53pm |
Guys,
28th Oct 2020 10:21am |
