Home > Technical (L322) > Oil on rear tailgate
Rosco
As the heading suggests I have spots of oil on my tailgate, not seen this before on my other 2. any ideas ? All working perfectly and no warnings or anything on the iiD, it does have a trailer attached for 95% of its miles, 2011 TDV8, any help appreciated, Rosco
Post #567307 17th Sep 2020 2:05pm
Have you got a dipstick ?
I got this with my TD6 when the oil separator got clogged up. Blew out the dipstick and oil was blown under the car and up onto the tailgate area.
Or could be some other oily leak..... .
Post #567309 17th Sep 2020 2:14pm
Rosco
Thanks Joe, allegedly no dipstick, it is minor spotting but unusual Thumbs Up
Post #567317 17th Sep 2020 4:44pm
Dreaded oil cooler leak i would expect Rosco... Runs down the rear of the engine then under the car! Big Cry
Post #567350 17th Sep 2020 10:41pm
Rosco
Thanks Craig, as I suspected, can I run if for approx 500 miles until I can get it done?? Thumbs Up
Post #567355 18th Sep 2020 6:17am
Rosco, you can run them for months like it sir... as long as you keep it topped up then the only damage it’s doing is to your driveway and your nose 🤭
Post #567366 18th Sep 2020 8:22am
Willfen57
Sorry to jump on but my 4.4 petrol also shows signs of oil up the tailgate and some.nasty patches on the floor looks like rear of engine above starter motor would mine be the same issue thanks
Post #567370 18th Sep 2020 8:50am
No sir, yours would more than likely be the rocker cover gaskets...
Post #567371 18th Sep 2020 8:53am
Willfen57
Many thanks Craig I'm.alsp having a can bus issue if any one is wise on this
Post #567375 18th Sep 2020 9:24am
kevinp
I used to have a similar issue with a previous white car but only when towing my caravan. I presumed the bow wave of the caravan some how pushed the exhaust gases forward and onto the tailgate. So I presumed it was 'unburnt ' diesel.
Also the front lower part of the van was covered in a smearing of oily stuff. But towing with the range rover it doesn't happen any more probably because the exhaust tips point downwards. You say you tow a trailer most the time?? Just a thought.
Post #567386 18th Sep 2020 12:10pm
