![]() | Home > For Sale & Wanted > SOLD. Genuine Land Rover L322 Roof bars |
Spr1ngbok Member Since: 16 Jul 2020 Location: Hampshire Posts: 45 ![]() ![]() |
Bump |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Do these need the rails to fit in to or do they fit in the covered slots in the roof?
to be honest I am not sure As far as I am aware they fitted into the slots in the roof and then the screws in the bars tightened with an allen key
I could measure length of the end that would go into the slot if helpful |
That would be helpful, thanks.
The bit of the bar that goes in slot is 11cm long and c 7mm wide
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
These fit in the slots in the roof . One in the middle , one at the front
So no longitudinal rails needed?
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Correct - I had these in my L322 because I didnt want to have to fit roof rails
Thanks, Graeme.
Thanks, Matt. Dunc. The life you have is the only one you'll get; make the most of it. --------‐--‐-----------------‐------------------‐--------------------------------------------------- 2012 4.4 TDV8 L322 Autobiography 2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!) |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Had a set of these, yes the flaps flip up, if there’s a grub screw take it out.
