Home > Technical (L322) > ZF6HP26 Torque converter
Panoramix
Italy
It's time to replace the torque converter on my 3.6 TDV8
Does anyone knows is there are heavy duty TC on the market?
If yes, some feedback?
Thanks in advance
Post #566033 1st Sep 2020 6:24am
vbrab
Australia
RE HD torque convertor for TDV6 3.6
I also have been looking for such a torque convertor, and am assured by an LR transmission specialist and also by "world's largest land rover dismantler", that the torque convertor on TDV8 L322 and Disco 4 TDV6 3litre are the same, and "as "heavy duty" as comes for the HP6. Seems the torque convertor on TDV6 2.7's were less robust.
Seems anything more robust would have to be a special build by a trans specialist.
Post #566242 4th Sep 2020 12:51am
chief64
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
Ford US is using a copy transmission of the zf 6hp26, that should be more strong, and some company is using parts from this
(6R80) to make a more strong the zf box.
link to one company, https://roadblastertorqueconverters.com.au...-converter
https://www.aulro.com/afvb/l322-range-rove...parts.html
Info from LR Australia.
Post #566277 4th Sep 2020 1:17pm
vbrab
Australia
Thanks for that info Chief64, it looks like I can source 1 in Australia. It seems they were developed for drag racing here, so should handle a remapped 3.6 towing a large trailer over long distances.
I attach pic of 7 metre trailer, (all aluminium including chassis), that only weighs 1170kg with half that weight being the wheels and axles. I have towed this up to 5500k's at a time at its full 3.5tonne load, so looking forward to having a torque convertor that won't collapse.
Post #566343 5th Sep 2020 2:21am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Re: ZF6HP26 Torque converter
Thanks in advance
How many km or miles did tc make?? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #566977 13th Sep 2020 8:44am
Panoramix
Italy
180.000 km Thumbs Up
the same is happened to my Discovery 3 2.7TDV6, at the same km Confused
Post #567007 14th Sep 2020 9:57am
Panoramix
Italy
Thanks chief64.
I'll try to contact them
Post #567008 14th Sep 2020 9:58am
