Home > Technical (L322) > AC fuse question |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Never seen that done before. To me it's possible that the position Fuse 12 goes in is in some way damaged / unusable and someone in their wisdom has decided to byepass the problem by taking a supply from Fuse 34 and feeding it through a fuse back to Fuse 12. If you can't get the Fuse 12 position to work I suggest installing a piggyback fuse connector in position 34 and feed fuse 12 that way. The way the supply has been picked up from fuse 34 at present is at best dubious. |
27th Aug 2020 8:36pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
30th Aug 2020 8:01pm |
Fuse 12 should indeed be 7.5A.
31st Aug 2020 7:49am |
