Home > In Car Electronics (L322) > 2005 L322 Replacement head unit confusion
Lurpak
England 2005 Range Rover HSE Td6 Stornoway Grey
Hi,
I’ve read quite a few posts in here about some incredible replacement head unit stories etc. But all I’ve done is confused myself?
I’ve got the OEM head unit and the separate touch screen nav screen with 4x4 info.(DVD Nav currently not working, disc not recognised)
Is there a suitable CarPlay system that can be used?
DonI need an electronics degree to fix it?
As usual, any help would be wonderful thanks.
John
Post #565418 25th Aug 2020 8:22am
Weegie
If your FF is MY2005 to 2009 (your signature suggests it is) this is a possibilty for you.
https://www.fullfatrr.com/forum/topic53128.html?highlight=navtool
I. and a number of others, have fitted it and am very pleased with it. It emulates your phone on the touch screen and does not require stripping out the head unit. All the installation is in the left rear cubbyhole in the boot.
Press of a button switches between it and the original system.
I use it with an iPhone.
The threads covering pre-2005 and post-2009 involve removing the head unit. AFAIK it is not an option with the 2005-2009 MOST units.
HTH John
GAP iiD BT
Post #565419 25th Aug 2020 8:32am
Lurpak
It would help if I gave the right spec in my profile, it’s a 2005 L320 🙄
2005 sport HSE with the dual head unit
Post #565421 25th Aug 2020 8:47am
Weegie
In which case you might get a better response on the sister forum - https://www.rrsport.co.uk/forum/
Sorry can't comment on the Sport. John
GAP iiD BT
Post #565423 25th Aug 2020 8:54am
Danwilderspin
yea the sport can use the same solution mentioned above they have it on their website. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #566122 2nd Sep 2020 4:29pm
