Home > Wheels & Tyres > Sorry I know it’s been done. Tyre pressure sdv8
Wilpert
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
As per title, I don’t have a handbook and missus is on way to drop family to Heathrow.
Tpm just told her rear tyre is only 31psi
She can go into a garage and top up the air,
Model is 2016 sdv8 I was going to say 40psi all around?
Help please 🤔
Edit should have said 22” wheels. Thanks
Post #564757 16th Aug 2020 4:31pm
owners and workshop manual are in the wiki..
but you can get the proper pressures from the instrument panel menu... ... - .- -.
Post #564759 16th Aug 2020 4:40pm
Mine are printed bu the drivers door - ‘only 31’ doesn’t look overly problematic......
Post #564761 16th Aug 2020 5:36pm
Wilpert
Thanks both,
She went into panic mode and put 40 in each.
The car is not usually well loaded so I will let a bit out and take it to 37 rear and 34 front.
Post #564762 16th Aug 2020 6:33pm
33/36 front rear.
Mine came with more in and reducing it down improved the ride a bit.. There is nothing that can't be fixed with a hammer😜😜
Post #565083 20th Aug 2020 4:47pm
Dave.N21
Australia 2016 Range Rover HSE SDV8 Indus Silver
I've got 22inch also and just topped up with 36psi all round, I just take in consideration that once you start driving and it is hot air pressure will rise. Always optimistic, unless Censored really hits the fan
Post #578487 5th Jan 2021 6:24am
