![]() | Home > Technical (L405) > Window down |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
never seen that before , especially on a new vehicle...
1880 Member Since: 18 Jul 2020 Location: London Posts: 26 ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Ive not had the pleasure of playing with drop window glass in the facelift 405 but maybe its like the D4 system? Two big plastic clips that holds the window to the runner? There are videos on YouTube to show you how too remove the window |
Thanks Craig, I’m not the expert, but it did look as you describe, with two big clips on two runners. Took the guy an little while to reposition it and get the glass then slotted back between the seals correctly.
Hay, it could be far worse sir, trust me!!??! |
Thanks Craig! I’m sure that’s the case! Have already had to have a tyre replaced 1 week in though, courtesy Mrs 1880...
Ah yes I remember now... Maybe your window is a direct response & due to the contact with the kerb sir |
The same thought did occur to me... L405 P400e Autobiography Eiger Grey (MY20) |
