Home > Technical (L322) > BMS / Alternator Operation
It’s certainly a good start. When I did my alternator there was a huge airlock that took a long time to work through, until eventually the expansion tank started to fill but the amount of air the came out was ridiculous. I bled mine until the cooling fluid started to bubble out through the bleed valve and all was ok, no leaks to speak of. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #564746 16th Aug 2020 3:14pm
