Home > In Car Electronics (L322) > Extra touchscreen in an L322
Page 1 of 3 123>
mjdronfield
Just seen this on the Range Rover FB group.
Can’t make my mind up if I like it....
Though if I could speak another language it might help 🤣
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #564247 11th Aug 2020 7:38pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Might as well just glue an iPad to your dash board looks stupid there and right in your field of vision
Post #564249 11th Aug 2020 8:20pm
mjdronfield
That’s what I thought. Just not sure where else it could go..... even if you were Land Rover.... there’s not even any room to have it lower into the dash...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564253 11th Aug 2020 8:42pm
mjdronfield
Appears it’s this.... though it’s Italian.....
https://audioelite.it/prodotto/land-rover-vogue-android-octacore/
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564254 11th Aug 2020 9:12pm
GGDR
I quite like it actually.
I rigged up a removable iPad nearly in that position but because of the removability, it was a hassle to put up and then away each journey:
Works well though, waze, IIDTool etc
Problem is als that it is too high and I was thinking I needed a tablet with a more letterbox aspect. Which this one is.
. Cheers, Greg
Post #564256 11th Aug 2020 9:51pm
GGDR
just seen the price Rolling with laughter
forget it!
. Cheers, Greg
Post #564257 11th Aug 2020 9:59pm
mjdronfield
Yeah.... it’s not cheap 🤣
Like your setup.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564258 11th Aug 2020 10:02pm
wayneg
I have an android head unit with GPS etc unit but also sit a tablet or my phone on a thin alloy channel when I want a bigger screen. Super easy as it connects via Bluetooth. The channel is glued but can easily be removed with no sign it was ever there. I have seen a similar channel being sold as an accessory, I think they nicked my idea
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #564272 12th Aug 2020 7:38am
mjdronfield
That looks much better for Sat Nav etc.
I usually have an argument with the factory Sat Nav 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564273 12th Aug 2020 7:48am
GraemeS
I use this bracket to hold a 10" screen but only fitted for trips. My suction cap is inverted.
https://www.fullfatrr.com/gallery/albums/u...BPB117.pdf
Post #564278 12th Aug 2020 9:33am
mjdronfield
So, on a bit of a tangent..... do you chaps who have another unit, ie iPad or tablet for Sat Nav.... do you tether it to your phone to get the mobile data? I have a data limit on my phone contract so it wouldn’t last long. Maybe I’m missing a trick?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564294 12th Aug 2020 10:47am
GraemeS
I have maps on the tablet but they're not for street guidance.
Post #564297 12th Aug 2020 11:04am
Purpose made slide in bracket for use with an iPad mini for the odd occasion I need a map.
Post #564335 12th Aug 2020 3:38pm
mjdronfield
That set up looks good. I’m a bit old fashioned and would still prefer to use the in car system, but it never picks the fastest route by default, and then continually tries to reroute you back to the planned route, rather than calculating again from current position. I’ve moaned about that before on here though 🤣.
Went to Doncaster from Chesterfield..... it’s just M1, M18.... but no.... all the way up the M1, it’s trying to make me turn off and go through Sheffield..... never trusted it after that..... rant over.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #564343 12th Aug 2020 3:59pm
there's some good suggested nav mountings in this thread...
https://www.fullfatrr.com/forum/topic48264.html?highlight=sat+nav ... - .- -.
Post #564348 12th Aug 2020 4:13pm
Page 1 of 3 123>
