Home > Maintenance & Mods (L405) > Any Titanium Experts?
So, im toying with the idea of Titanium wheel nuts for the FF! A friend gets lots of titanium bolts/racing parts made for the exotic car market and although they are very expensive, is there any downside to using Titanium? We all know about Wrington engineering making Stainless wheel bolts but they are VERY heavy!
Anyone got an opinion?
Post #563529 4th Aug 2020 9:43am
Amazing
https://www.azom.com/article.aspx?ArticleID=1336
the chart shows a big reaction with aluminium in sea water...not relevant? salty winter roads may cause issue and no playing in the sea.
I would say...not suitable..
also titanium like aluminium can sieze (pick up, galling) so needs anti–sieze compond which will change the effective torque meaning wheel nuts will be over torqued.(std wheel nuts should not be oiled as you know for this reason.
race cars get taken apart all the time so long term corrosion is less noticable.
I did make some nice lash caps from Ti for a cologne engine in order to correct rocker angle after a bithead modification.
a tyre brand change can save more unsprung weight it is better to have and not need then need and not have
Post #563535 4th Aug 2020 10:39am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
This seems like an excellent move as unsprang weight in a FF is so critical. letters not necessarily in the right order
Post #563545 4th Aug 2020 11:44am
Philip
I’d do titanium wiper arms first, CofG and all that.
Post #563551 4th Aug 2020 12:10pm
Well ive ordered a couple of sets for the RR & er indoors Disco as im sick of JLR's efforts!
Post #563734 5th Aug 2020 9:40pm
AJGalaxy2012
Theft will potentially be an issue, you've at least doubled the value of your vehicle LOL
Titanium is a great metal, nightmare to machine and work with, it wont corrode though. I used to work in the Steel Industry and our rolling mill was one of the few that could roll titanium but temperatures were critical, a very narrow window that it could be rolled, outside the window it had to be scrapped and start again. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #563742 6th Aug 2020 4:35am
They are making them with a 17mm reverse allen key head (exactly the same as Ferrari ones) so i need a tool to remove them and there's no risk of scratching the alloys installing them Thumbs Up
Post #563770 6th Aug 2020 11:31am
AJGalaxy2012
They sound good, any photos's or website link? Just out of interest, I dont have a fatty any more. BMW i3 Electric Car
Post #563773 6th Aug 2020 12:06pm
Heres a pic of the cad drawing they sent me over to check measurements... Thumbs Up
Post #563832 7th Aug 2020 12:48am
supershuttle
Having just bought the stainless ones and I needed to change a wheel so I thought it might be helpful to crack out the scales. Craig is indeed right the OEM nuts weigh 120gm the Stainless ones 135gm each so a full set of 20 adds about 300gm to the total weight of my Range Rover if i’ve got my arithmetic right - I think I can live with that. The Stainless ones were expensive enough i’m sure the Titanium ones will be be beautiful and practical as well as lighter but probably more expensive again. Geoff
Post #563836 7th Aug 2020 7:11am
i've moved ''your nuts'' thread up to the 'mods' section Craig.. Thumbs Up ... - .- -.
Post #563839 7th Aug 2020 8:09am
AJGalaxy2012
Although the stainless wheelnuts are 300g heavier than the standard ones, the Rangie will have shed more than 300 g of it's metalwork as rust so it's still better Laughing BMW i3 Electric Car
Post #563841 7th Aug 2020 8:48am
You can move "my nuts" to wherever you like pal! "Just be gentle with um please sir" Thumbs Up Thumbs Up Thumbs Up
Post #563851 7th Aug 2020 10:57am
Geoff, its not necessarily the weight aspect im thinking of... More so the long term corrosion (like with your stainless ones) and the aesthetics over and above the standard ones...
I love the way they look on the Ferrari and thought they would also have the same visual effect (and long term corrosion & unsprung weight saving) on my FF Thumbs Up
Pic of them on the afformentioned Ferrari sir Thumbs Up
Post #563853 7th Aug 2020 11:04am
are the Ferrari ones bolts?
i gather the titanium nuts will still stick out like the normal LR ones.
let me know when Lorna's out and i'll come round to look at your new nuts Mr. Green Wink ... - .- -.
Post #563854 7th Aug 2020 11:09am
