Home > Technical (L322) > Harmon Kardon impeadances.....
Thegingerone
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
Hi guys, I’m after information, I’ve tried searching in the forum but couldn’t find what I was after
2006 L322 with HK Logic 7
After narrowing down a rattle in the rear door, it turns out the woofer is at fault, sounds as though it’s dropped a coil and sounds horrendous
My question is, does anyone happen to know the impeadance’s of the factory speakers. I’ve got a set of focal components from which I can make use of the woofer driver, but I don’t want to go burning out the factory amp in the process
Thanks guys! [/i]
Post #563275 1st Aug 2020 8:16am
Pawl
Typically in Land Rovers it's 4 ohms.
However it's not mentioned in the Range Rover Workshop manuals I have, so maybe don't take as "gospel" Paul,
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Post #563283 1st Aug 2020 1:17pm
