![]() | Home > Technical (L322) > 4.2 SC knocking and misfire on #5 |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Surely take it back to whoever did the work.
ivan1566 Member Since: 15 Feb 2019 Location: Dubai Posts: 19 ![]() ![]() ![]() |
Just about to, but wanted to have some idea as to Help enforce the fixing of the fault under warranty |
Well if it only started knocking after they did the head gaskets it's down to them unless you've put a load of miles on it since then?
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 76 ![]() ![]() ![]() |
If you have a knocking with a misfire it could be causing the coupler to be noisey in the snout of the Supercharger. Sort the misfire and it should sort the knock ur hearing. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
