Home > Maintenance & Mods (L322) > Speedo needle not illuminated
Danwilderspin
Strange one... the wife told me the speedo needle didn’t light up with the lights (all other needles and cluster did) I went in it was fine about four months ago and ever since intermittently I have witnessed this too until about two weeks ago it hasn’t come back on... then tonight the rpm needle did the same! Any ideas I see on the disco and sport forums this is a common issue due to burnt out tracks but wasn’t sure if this was the case here or anyone had witnessed it? If so I will have to take to an auto electrician to bridge the track I guess Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575601 9th Dec 2020 10:29pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I had some lamps go out on my dash a few years ago so removed the dash. On the rear of the unit there are plug-in bulbs , If I remember correctly 2 types . One type for the main dash illuminations and another type for the guage needles etc. Unfortunately cannot recal what type they were as it was about 4-5 years ago. Had to take the end caps and top dash cover of to remove the binacle though and took about 2-3 hours all told from start to finish .
Post #575703 10th Dec 2020 10:28pm
Danwilderspin
I’ve nailed tearing down the dash I can do it in under 15mins now I’m not joking and about the same assembly lol - but I have had this out befor for another rein and they are all leds I guess it’ll have to come out again and be repaired...
I have got an identical cluster same age style etc in the shed - is there any chip I can swap from one to the other that holds mileage
Etc? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575715 11th Dec 2020 12:25am
Im pretty sure they are VIN locked Dan, to stop clocking in its most basic form!
That said, when i changed my 322 multimedia screen from single to duel view, that was VIN locked BUT, importantly, the parts i needed from inside were not!
So, maybe possible to swap the offending board over to your clocks? Thumbs Up
Post #575727 11th Dec 2020 9:15am
