Home > Technical (L322) > Battery Light Flashing and then staying on |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
As a quick comparison test you could see what the readings are using a jump lead from a clean chunk of engine to the battery negative.
20th Jul 2020 5:22pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Almost certainly the alternator is on its way out
20th Jul 2020 10:41pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Sounds a good idea, 99% certain it is the alternator but worth a check. |
21st Jul 2020 8:55am |
Thanks the car isnt going anywhere right now so will swap the alternator soon btw its done 155k miles so its done ok! Just strange that it seems to have gone quite quickly rather than slowly dropping voltage? Also no strange sounds coming from it. |
21st Jul 2020 8:57am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Just done this - 168k and it was the carbon brushes that were worn. Changed them myself and all back kicking out 14.1 v again. Initially was the same as yours at 11.5 volts. |
21st Jul 2020 8:31pm |
I assume thats an alternator out job? Where did you get the brushes? |
29th Jul 2020 1:37pm |
