![]() | Home > Maintenance & Mods (L322) > rear air spring wont come off |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
A bigger pry bar...!!! you can tell if it has air in as if it hasn't it will be all limp and flaccid, if it has air in it will be hard and erect...
Did you remove the lower shock absorber bolt? This will give you more "swing" on the suspension arms when you use the bigger pry bar to hold it down, while you remove the air spring. .
