Home > Maintenance & Mods (L405) > spares - where can I get this?
Page 2 of 3 <123>
notanrdx
United States 2017 Range Rover TDV6 Fuji White
What model year? The 13-17 PN is LR047409 I believe.
Post #561946 18th Jul 2020 5:38pm
Wilpert
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
thanks i will look that up.
Its a 2016 RR vogue SE SDV8
seats are almond leather so not sure if its colour coded.
i will look up the part number - thanks
NOPE: looked it up, thats a grille speaker, I just want a cover.
Do lanr rover have a search facility on their site?
Post #561948 18th Jul 2020 5:45pm
crikey, if that is the part number they aint cheap... ... - .- -.
Post #561950 18th Jul 2020 5:48pm
MarkinNantwich
United Kingdom 2011 Range Rover Vogue TDV8 Ipanema Sand
Very expensive for a little plastic grill, some in the US at 180usd
Post #561952 18th Jul 2020 5:52pm
GGDR
There are 405 parts available at breakers and / or on ebay
But you may be able to graft another similar clip onto the rear of the grille.
. Cheers, Greg
Post #561953 18th Jul 2020 5:54pm
GGDR
Also this: https://www.google.com/url?sa=t&rct=j&...mDkeh3w0my
. Cheers, Greg
Post #561955 18th Jul 2020 5:57pm
notanrdx
The almond PN is LR047413. Also that’s for the LH. The RH might be a different PN. From the picture it looks like it’s just missing the typical metal barb clips.
Post #561958 18th Jul 2020 6:12pm
Wilpert
thanks,
i have emailed a supplier and given that number and attached the pics.
I cant seem to find a UK site that displays the item.
Even when this is done, i still need to get the flipping speakers working, which is proving a challenge.
Post #561964 18th Jul 2020 6:36pm
Wilpert
That’s the thing. The heavy handed fool has broken the clips and they are plastic.
Tbh I could do as Stan says and use double sided tape but it won’t pull tight and clip into place and I’m being a bit “new car ish”
I just hope the speaker fix isn’t a challenge but if the rest of the system works then it can’t be too serious ..... can it ?
Post #561971 18th Jul 2020 7:09pm
a wild guess this is (I'm sounding like yoda)
try a battery reset...it might just re-start all the electronics ... ... - .- -.
Post #561975 18th Jul 2020 7:29pm
Wilpert
is that just a case of disconnect and reconnect battery and will it mean that I would need to reset everything afterwards?
I suppose it has to be worth a try.
Post #561980 18th Jul 2020 7:57pm
notanrdx
Do you have access to a diagnostic tool for checking for DTCs? In theory, if there is a disconnect between the amp and the speakers, there should be a DTC logged somewhere. The seat speakers have a dedicated channel on the audio amp.
Post #561983 18th Jul 2020 8:06pm
Wilpert
its been plugged into a diagnostics tool recently but no fault code re radio or speakers, although i suppose the code could have been cleared?
I wish I could just get my hand under the seat and plug something in that may have come adrift.
I just cant imagine that two speakers would both fail at the same time.
Post #561990 18th Jul 2020 8:53pm
GGDR
I was wondering about the under-seat connector....
Best approach is always to start with the obvious.
Loosen but don't remove rear two seat bolts. Then remove forward two bolts. You should be able to tilt the seat backwards, paying close attention to stressing any wires.
Have done this on my L322 and there is enough slack to tilt it back safely.
Don't disconnect anything, there will be an airbag connector under there. Just try to identify the speaker connectors and check.
. Cheers, Greg
Post #561993 18th Jul 2020 9:14pm
MarkinNantwich
I must try that
Post #562003 18th Jul 2020 10:31pm
Page 2 of 3 <123>
