![]() | Home > Technical (L322) > Hitachi compressor still unrepairable? |
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 ![]() ![]() ![]() |
I used this kit and it was certainly working better afterwards.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6765 ![]() ![]() ![]() |
I had problems with mine, tried the repair kit, didn’t work, so ended up buying a new one from E-bay at slightly more than the repair kit.
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
I rebuilt mine and it works great. Best bet is to do the desiccant and filters first and only do the pump if that hasn't solved your issues. Rob 05 L322 4.2SC
I’m resigned to having to replace mine.
Any recommendations on which replacement to buy? |
procee Member Since: 05 Oct 2016 Location: Grampian Posts: 28 ![]() ![]() |
Is there any way to tell which compressor you have without taking it out? I have a horrible feeling mine is needing replaced. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Open the cover.
I drilled a hole on copper filter.
