Home > Technical (L405) > A pillar outside trim
V8burble
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
Hi all
How 'should' the A-pillar outer trim be affixed? Should there be clips? The LH trim on mine has pealed away at the top. It has been stuck on with double sided gummy tape.... I suspect it's had a replacement screen at some point in its history. Anyway, rather than it fly off never to be seen again I'd like to get it back in place and pref as it's supposed to be held on. Thanks Thumbs Up
Post #560108 3rd Jul 2020 4:05pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
It is glued. This is how it is removed/refitted:
https://www.fullfatrr.com/gallery/albums/u...LATION.pdf
Post #560186 4th Jul 2020 10:39am
V8burble
Thank you much appreciated. Yes it looks like whoever was here before me just chose the wrong adhesive tape... which loosens when wet. I’ll strip it all off, IPA and restock with 3M tape. πŸ‘πŸ»
Post #560189 4th Jul 2020 10:55am
adara
You are welcome. I'm wondering myself if the trim has to be removed for windshield replacement...
Post #560272 5th Jul 2020 5:58am
V8burble
I did some digging, apparently not. So unless damaged it’s good to stay πŸ‘πŸ»
Post #560278 5th Jul 2020 8:33am
