![]() | Home > Maintenance & Mods (L322) > Identify please |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Morrison
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Good Luck with the new one Simon and also in selling the other two :0
Got the car last night and when checking out the boot found the box for the receiver hitch bolted in without the hitch in place. Went looking further and found towbar and electrics in place so just need the receiver and the hook to complete. As this will not be used as a general towcar I will just remove the bumper trim and fit the receiver as and when necessary. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
Looks like you're well sorted then Simon. Sounds like you wont do it often, but fitting/removing the tray, receiver, and swan neck each time will take quite a few mins and mean getting under the car - inevitably in the wet - when you need it. So quite a disincentive to use it! Mike - MPx
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 ![]() ![]() ![]() |
Hi I’ve just fitted one of these from powerful uk it’s called an exterior design kit looks better than the standard front set up.. I bought the bottom grille thinking it would fit onto a standard bumper but it didn’t so I have one for sale it’s brand new..they are for sale (exterior design bumper) with out the bottom grille on eBay |
