![]() | Home > Maintenance & Mods (L405) > L405 - Upper tailgate/liftgate Interior trim removal. |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
There is a useful thread here:
On my 7th RR plus various other JLR vehicles |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Phil
I managed to fit the rear camera without taking off the spoiler, and the DAB reception is fine. If you want the detail of the fit let me know and I’ll post it up. MY23 D350 HSE
Phil
I had to pop out and grab a few more photo’s in between the showers. Here go’s:
Pull off the side panel.
Also pull off the bottom panel. In both cases there are 4 fixing points. Start at one end and move along. It’s a bit scary for the inexperienced but they will come off (and go back on) with a bit of brute force.
I spent a couple of hours with some wire trying feed from the top of the long rubber grommet inside to the bottom of boot door. In the end I did what one of the others did and drilled a small hole for the cable to exit near the top of the door and then ran it down the outside of the door under the side panel before re-entering door via the large round grommet.
Things get easier now. Position the rear camera on the bottom panel which is now hanging loose, and push is back together. All done!
Any questions give me a shout. Good luck! MY23 D350 HSE On my 7th RR plus various other JLR vehicles |
Brilliant write up!
