Home > Technical (L322) > Injector leak back - too much fuel in return line?
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Recently doing a leak back test on my TD6 I found that I had a lot of fuel come out of the return fuel hose while testing.
About 400ml in a few seconds, the injectors only just released enough fuel to reach the measuring bottles - about 700mm of tube.
All injectors were similar so all good there.
However previously using the same kit and setup i've run the engine for over a minute without coming close to filling the bottle I put the return hose in.
The only change is that ive fitted a new lower milage engine, runs and drives well and no codes generated.
Any idea why i'm now getting so much fuel out of the return hose??
Post #557016 9th Jun 2020 8:04am
Gsxr1250dave
Most of the fuel is returned to the fuel tank its normal
Post #557059 9th Jun 2020 12:16pm
JohnK
This is coming from the disconnected return line, that would normally be connected to the top of the injectors, I havent traced it but assume its going back to the tank, hence the concern over the amount of fuel coming the "wrong way"
Post #557081 9th Jun 2020 1:40pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I Believe you are supposed to clamp these return lines when doing the test otherwise fuel spills.
Post #557284 11th Jun 2020 10:18am
