Home > Technical (L322) > DPF red warning |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
I wouldn't
4th Jun 2020 12:53pm |
aggraa Member Since: 16 Apr 2018 Location: diss Posts: 33 |
Thanks for the responses. Currently I am in Bulgaria been stuck here because of lockdown. We had stricter rules here than in UK so couldnt travel anywhere since early March.
4th Jun 2020 1:10pm |
ah ok so you you are at home - good thought you were stranded!
4th Jun 2020 1:13pm |
Hi Greg.
4th Jun 2020 1:24pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3139 |
look at my threads ref this. It was a cracked inlet manifold only discoverable by HIGH pressure smoke test. could be a tiny crack in a pipe, not visible to the eye.
4th Jun 2020 1:53pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
How did you reset with an iid tool, I thought when red, they needed a forced regen? |
4th Jun 2020 2:05pm |
Yes I agree to invest in an IID.
4th Jun 2020 2:18pm |
I only managed it once, before the soot level got to 28.5 (forced regeneration cut off). I did an oil change as fuel in oil level was reading 12 (Cut off is 7!!)
4th Jun 2020 5:11pm |
so can anyone answer my question? |
5th Jun 2020 2:04am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
If it were me:
5th Jun 2020 7:13am |
Hi. I have just got back from the local garage , I asked them to do check the fault codes and do a forced regen.
6th Jun 2020 9:06am |
DPFs are more resilient that some say. A dealer will tell you to buy a new one. But it may be clean-able.
6th Jun 2020 9:10am |
I had Terraclean clear my DPF for £200. above a level of 28.5g the LR equipment will NOT be able to force regeneration.
6th Jun 2020 10:11am |
Thanks for the replies, I am gonna take the forum advice and not drive the car anymore.
6th Jun 2020 10:26am |
