![]() | Home > Technical (L322) > L322 TD6 Intermittent Non-starting |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
Go to any motor factors, have them test your battery, once its confirmed |
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 ![]() ![]() ![]() |
Fair enough. I've ordered a Yuasa HSB020 battery from Halfords and will get it installed this afternoon. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
A little direct maybe, but I think he got the message! ![]() Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I’d say if it runs fine after the easy start, prob injectors.
Ignore my post above.... was replying to your query on the previous page....not read the posts after...oops...
So, new battery fitted - no start; same symptoms as before.
ok, well that's discounted the battery so tick that off the list.
Well your not pratting about with jump leads anymore, so it's ruled out the battery issue, next check is glow plugs
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 466 ![]() ![]() ![]() |
I had the same issue on my TD6. Would start fine one minute, then just spin over and not fire the next time. It did turn out to be the secondary-fuel pump, they're easy to do, just inside a panel under the N/S/R floor, you should see cross head screw if you pop underneath the car then remove the small plastic panel, you will smell of diesel once complete. If you want to check it, next time it does it get someone to lean underneath with lump of wood and bash it while turning the key, it usually shocks them into life. (How I proved mine) |
That’s the one I said to wack.... easier if you take the plastic cover off.... though mine wasn’t intermittent. Just stopped working.
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Another vote for the secondary fuel pump here, mine had similar symptoms.
Cheers guys,
My code reader said exactly the same and it was the rear pump.
Cheers John. Will try the spanner trick to see if it gets it going but certainly looks like the most likely cause now. |
