Home > Technical (L322) > In tank fuel pump td6 |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
John
22nd May 2020 9:37pm |
Here's your starter for 10
22nd May 2020 9:48pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I did mine a couple of years back with a cheap pump from China 15pounds delivered. Its still going strong. You will also need a foot of fuel hose and a couple of jubilee clips. At the time I was not ready with the hose and was worried about using normal rubber EFI hose submerged in diesel but can confirm it's not been an issue. ( The fuel pump wiring on the TD6 is not an issue unlike the TDv8). Here is a link to the pump I used... https://www.aliexpress.com/item/3282411991...4c4duvodRB 2007 TDV8 VSE
23rd May 2020 2:40am |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
Cheers guys im on with today so ill show what i find 👍🏻 |
23rd May 2020 6:33am |
Ok guys new intank pump fitted and just as i had a fuel pressure gauge lay about of my sd1 v8 i put it on the pipe outlet of the fuel filter and on idle its just over 3 bar of fuel pressure is that about right both pumps are buzzing away nicely |
23rd May 2020 3:35pm |
OK John good result
23rd May 2020 8:55pm |
Johnsd1v8, out of interest what hose did you use after removing the shrunk hard plastic connecting the pump. I was very concerned using normal EFI hose in a submerged fuel situation. I still have a piece of the hose I used in a jar full of diesel on my workbench which I can check the state of. When my pumps were both changed it really transformed the drive. Before, although the car started and ran fine, if I floored it at 50mph plus it just bogged down and acted like it was running out of fuel 2007 TDV8 VSE
24th May 2020 1:24am |
It all came with new hose i took a punt on this off amazon i know its only a cheap one but ive read on hear about cheap ones still going strong 3 yrs later i was impressed with the fast delivery also
24th May 2020 6:27am |
That seems a great price for the complete pump and sender assy. I only got the pump then swapped it over using the old float assy 2007 TDV8 VSE
24th May 2020 6:55am |
I was looking at doing that myself but then i seen that £50 and though ill try it as its not hard job to do so i dont mind if i end up doing it twice |
24th May 2020 6:59am |
