Home > In Car Electronics (L322) > Removing a factory-fit tracker? |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
I found a, tracker glued up under the rear offside, shelf inside the cubby locker, small black box the size of a, cig packet,wires,going to it obviously, in my 2007tdv8,it has printed on it" tracker" and, some obscure numbers?? No idea if it works, no idea how to get it to work or contact "the tracker company", so it sits, there, I've considered cutting it out.. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
15th May 2020 4:06pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
The 322 did not have factory fit trackers. The LR approved system was from Trackstar and was a post-build fit, typically at dealers. Trackstar were taken over but if you Google 'Trackstar car trackers' you will find the company that now operates the system. Subject to verification of ownership etc they ought to be able to help you. Only Range Rovers since 1988 |
15th May 2020 4:39pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8541 |
As above, the Unlike the 405 the 322 wasn’t fitted with a tracker at the factory.
15th May 2020 5:32pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Whereabouts in the country are you?
4th Jun 2020 8:29am |
