Home > Maintenance & Mods (L405) > Windscreen washer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
mine are more of a fine mist than the older spray type so i doubt if a needle would clear the holes...an air hose should blow the curd out..
14th May 2020 10:06am |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 75 |
Yes agree , mist
14th May 2020 10:14am |
WM download link is in the wiki.. ... - .- -.
14th May 2020 10:20am |
14th May 2020 12:18pm |
Can’t find it Stan, but thanks, I’ve found loads of other things! |
14th May 2020 12:32pm |
tis a labyrinth of info in there..
14th May 2020 12:59pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Is that with or without lemon Stan ? 2003 Range Rover Vogue TD6 |
15th May 2020 8:14am |
someone is sharp today Brian... ... - .- -.
15th May 2020 8:26am |
Indeed, I've just cut myself on my razor sharp wit - pass the plaster please 2003 Range Rover Vogue TD6 |
15th May 2020 10:05am |
i best not mention your spelling mistake in the other thread... ... - .- -.
15th May 2020 11:14am |
Shows you're paying attention in the cheep seats. 2003 Range Rover Vogue TD6 |
15th May 2020 12:56pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I use a single strand of wire from an old bicycle brake cable or similar if you have one which are very thin but rigid madam |
26th May 2020 7:30pm |
