Home > Maintenance & Mods (L322) > Hi (my first post) and a couple of silly questions
Kent_newbie
Hi all,
FFRR Newbie here; just had a very nice example of an 07 3.6 TDV8 delivered (grey with black leather).
Anyway, only minor thing - it has a sticking caliper, so i'll be sorting that myself; my silly question, is there anything to note about jacking the car up? I've had other cars previously that, with their trick suspension, you need to put it in a certain mode to prevent trying to level itself the whole time?
2nd question... it has Grabber AT3s on it, what pressures should they be run at for normal road driving?
Thanks all,
Post #553606 12th May 2020 6:33pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Welcome!
Ref jacking up: leave the height at normal or access and then when it is raised, keep a door open which stops the wheels trying to level themselves.when you release onto the ground again they should automatically reset correctly. Make sure you use the proper jacking points if poss or use the chassis. Always use axle stands as back up as these are heavy ladies.
A lot of people rate the Mercedes jacks as most don’t get high enough to get the rangie’s wheels off the ground.
There is loads in here ref all your points so a quick search will see you right.
Post #553614 12th May 2020 6:45pm
mpirie
Fronts should be 33 psi and the rears 36 psi, though some run 36 psi all round.
Mike
Post #553615 12th May 2020 6:47pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Welcome!
As Dolphinboy wrote, sound advice.
As for the tyres pressure, I have the same type and keep them on 33 front and 36 rear, if I remember well. There's a table on the driver's door pillar under the lock. That's the one to follow.
Post #553616 12th May 2020 6:50pm
Weegie
33 front 36 rear here.
BTW there are no silly questions on here. Thumbs Up John
GAP iiD BT
Post #553619 12th May 2020 7:04pm
Kent_newbie
Perfect, thanks guys.
Yes the pressures say that for the supplied tyres, but I'm still fairly new to off-roading (bar messing around green laning in my brother's Sportrak with proper mud slingers on!) - so didn't know if the more off-road slant of them meant pressures should be different. Did look on the website of the tyre, but couldn't see anything. Thanks for the feedback though, big help.
Post #553620 12th May 2020 7:05pm
