Home > Dealership & Service Feedback > West Hampshire recommendations - 2011 4.4tdv8
coopss
Forced regen to the levels down. Only seen the yellow warning once since I’ve had it and it cleared itself
Hopefully will stay down - need to get the BT gap tool to monitor it
Post #555219 25th May 2020 8:45am
DrRob
Indeed. Usually caused by 2 things:
1) Short, frequent journeys with no long runs. You'll be forever battling yellow and red DPF lights. Buy petrol Rolling with laughter
2) Induction air leaks will override any long runs as it fills up too fast Thumbs Up
Lots of info on here for usual culprits of no.2 = 4 x original flimsy donut hoses, inlet manifold leaks or loose throttle body clip/hose
Might use Gotts for some preventative maintenance work in June. Did you get a loaner? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #555225 25th May 2020 9:46am
coopss
Trying to only use the car for long journeys (once I get the starting issue sorted). My work is 30 miles away down the a34/m3 so a good blast, but only ever 7-10 days or so atm.
I open the bonnet frequently to just have a look ! so will check those bits, if the 4 hoses you mention are on the top, they look fairly new. I’m going to document all the bits it’s had soon and contribute to that thread,
but it’ll take me a while!
Yep got a loaner - new Vauxhall (I think Corsa). Did the job
Post #555232 25th May 2020 10:10am
DrRob
No more DPF issues? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557520 13th Jun 2020 7:31am
coopss
All good so far!
It’s going back to them tomorrow to check out a vibration 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #557628 14th Jun 2020 5:55am
