Home > Maintenance & Mods (L322) > there will be one happy member
daveo
well there will be one happy member on here, Contraband he has had probs with his venture cam and after confirming the voltage found out that his cameras were not working, well i offered to fix them, some times what happens is when they get so flat the cells can swap polarity and need to be jumped back to the right way, any way he will be happy to know i have managed to get both of them working..now i will charge and discharge them a dozen times and they will be fit to go.... and he was talking about breaking them open..
daveo
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #59312 7th Apr 2011 6:59pm
nice one dave... Thumbs Up ... - .- -.
Post #59313 7th Apr 2011 7:01pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Is that one of those hand written £5 notes Very Happy 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #59317 7th Apr 2011 7:45pm
mzplcg
Go on then. I'm intrigued. How'd you do it without opening them up ?
Post #59324 7th Apr 2011 8:12pm
What can I say.... That's fantastic. Thank you very much.
I'll bet there are hundreds out there that would benefit from your touch!
You should advertise a repair service on eBay!
I'm looking forward to having a play with them.. Previously..
Post #59337 7th Apr 2011 8:43pm
daveo
as i said i will charge and discharge them for while then charge them and send them back, if you cradle is ok then they should charge as normal just dont forget to swap them around to save it happening again. V8 facelift Range Rover Autobiography 22" wheels.
Post #59339 7th Apr 2011 8:53pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I did some battery zapping the other day
I brought a lot of my 18v dewalt batteries back to life.
Post #59367 8th Apr 2011 9:22am
So if my cam didn't appear to be charging (like it isn't just now), could I reverse the polarity of the cam cradle in the glove box and do this>(Assuming the connectors are accessible?)
This post just came at the right time, as I was considering ripping the cam apart to see what the battery state was! Bow down Got - 2017 SDV8 Autobiography in Loire Blue
Post #59371 8th Apr 2011 10:11am
...or dave could tell us how to change the polarity of the cam... Thumbs Up ... - .- -.
Post #59378 8th Apr 2011 10:56am
daveo
no,no,....do not play around with the cradle,you could do big damage to the cars electrics,, i have a big bench supply unit that will give me from 1v up to 30v,now you need 12v plus to reverse a cell if its 12v, note you must be care full as if the cell have charging monitoring electric you can kill the hole thing like laptop batts, i have used this method for a number of years on any thing from model car battery's up to cordless drills, they can all suffer from cell memory. any way thats what i do but if you fry some thing trying dont blame me...
WARNING IF YOU PUT TO MUCH POWER THROUGH A CELL IT CAN EXPLODE.... V8 facelift Range Rover Autobiography 22" wheels.
Post #59529 8th Apr 2011 11:15pm
jollymuckshifter
2010 Range Rover Vogue 4.4 V8 Baltic Blue
I have one of these venture cams on ebay at the moment,currently sitting at 0.99P
Sorry for the thread hi-jack
Post #59779 11th Apr 2011 11:01am
daveo
ahhhh Exclamation but does it work V8 facelift Range Rover Autobiography 22" wheels.
Post #59858 11th Apr 2011 4:38pm
jollymuckshifter
sure does
Post #59876 11th Apr 2011 6:44pm
daveo
well put a link on here then..wont hurt to ave an extra cam V8 facelift Range Rover Autobiography 22" wheels.
Post #59878 11th Apr 2011 7:17pm
daveo
hi Contraband, they are on there way back to you all charged up and working, let me know how they go... you can register them both, i think you can register up to eight cams on one system.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #60107 12th Apr 2011 8:26pm
