![]() | Home > General > How do I buy a 5.0 Supercharged L322... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8442 ![]() ![]() ![]() |
Craig, I think you're right but I'm an impatient soul and the maximum I can lose is around a tenth of the depreciation already suffered by the last owners.. I can live with that..!!
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Pete I am still driving my 2007 4.2 with 195k on the clock as you know I redid all the underneath rubber and it is still a great car also only showing one little spot of rust so maybe go older and cheaper but of the option you are looking at no 2
WB,
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
My brake pipes had been done by LR which was handy. Haven't had to do anything on the suspension except replace two link bars on the front - the rest is all good but my car had been looked after quite well. The only thing I've just done is level the suspension all round using he IID tool which has improved the ride significantly - I'd always found it a bit harsh compared to my old 2008 TDV8
I am sure it won't be long before you are grinning from ear to ear.
WB, I have read a few reviews that said that the adaptive cruise wasn't a very good one... Mind you one of the reviewers missed the point, he criticised it for slowing the car down when he came up behind slower traffic...!!!! Doh
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
Adaptive cruise isn’t bad Pete. Main issue it has is slowing car on a bend on motorway as it thinks those in the lane to your left are directly in front of you....on a right hand bend.... not the cars fault really....the radar is looking straight ahead.
I think they all do that to an extent, read several reviews where they criticised it but weren't specific, other than the guy who didn't understand the principle...!!
FFRRWannabe Member Since: 19 May 2019 Location: Snohomish WA Posts: 39 ![]() ![]() ![]() |
I voted for option 2... that's the tactic I chose. 123K miles, bought from the original owner, over $20K in receipts since the JLR factory warranty ended at 50K. Timing chain guides, several water pumps, front air struts, lower control arms, several sets of brakes, and so on. Option three means you may have that higher price, and the $25K of normal service still ahead. I still paid for some of that maintenance as it was not truly a bargain, but 10 months and 10K miles and the only issue I had was the chaffed wires to the adaptive strut on passenger right side. 10 minutes and that fault was fixed. I did do all of the fluids as you mentioned before I picked it up, and had to put a set of Michelin Defenders on, and now I have to beg the SWMBO to get to drive it! BTW, the 510HP is simply intoxicating!
Thanks Wannabe, you sure can spend some money on these if you let a shop do the work..!! Pete
OK sounds like those critiques of the adaptive cruise had missed the point. Yes it does effectively slow you if the car in front slows and you can set the gap to your desired distance. I don't find it picks up cars in other lanes as I use it on the biggest gap setting which I prefer anyway.
John, TBH I'm not to keen on the 405, hence wanting a 322... |
Jpboost Member Since: 23 Jul 2018 Location: Gatwick Posts: 73 ![]() ![]() ![]() |
When I got my 5.0 s/c about 2 years ago, I went for option 3.
WB,
