Home > Maintenance & Mods (L322) > High Output Alternator Options
Jasdip
2011 Range Rover Supercharged 5.0 SC V8 Santorini Black
Does anyone know if there are any options other than qualitypowerauto.com for high output alternators for the 2011 Range Rover Supercharged?
Post #550148 13th Apr 2020 1:41am
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Hi
Have you tried these guys ?
https://canadianautoelectric.com/high-outp...nators.php
Laurie
Post #550151 13th Apr 2020 2:03am
Jasdip
They were one of the companies I sent a message to yesterday and am waiting for a reply. So far 1 company in Canada and 3 in the US have replied and said no (plus a bunch of local ones)Sad
Post #550153 13th Apr 2020 3:39am
Jasdip
Laurie915 wrote:
Hi
Laurie
They said no, and a few more no's lol
Post #550474 16th Apr 2020 10:37am
Laurie915
This mob is in OZ if you want to try ?
https://www.ebay.com.au/itm/New-Alternator...4422ac566d
Laurie
Post #550476 16th Apr 2020 11:03am
Jasdip
Laurie
This one is for a Range Rover Sport and also only 150A like the factory one.
Post #550574 16th Apr 2020 11:28pm
Jasdip
MarkinCW5 wrote:
Big range with big amp output
https://www.qualitypowerauto.com/item_379/...-Rover.htm
I’ve seen this one. I was looking to see if there were any other alternatives to consider as well.
Post #550576 16th Apr 2020 11:30pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Wow some of those units are making some serious current, to take advantage of this some serious rewiring would be needed under your hood. Thumbs Up
Post #550579 16th Apr 2020 11:38pm
Jasdip
I'm guessing you mean upgrading the engine and battery grounds to 1/0 gauge (or doubling up) and same for alternator to battery?
Post #550582 17th Apr 2020 12:31am
Jasdip
MarkinCW5 wrote:
I'm not to sure what the application would be, maybe secondary leisure battery or winch application but 300 amp is quite serious.
I'm looking to go with the 350A due to my electrical system being seriously strained by my sound system. When my bass hits, the truck actually jerks while accelerating. The voltage is dropping on the main battery from 14v+ to 12v and sometimes a bit less under heavy load.
I understand that the factory alternator is 150A and my amps are both max 100A each producing 1200W each. I've seen them draw up to 120A with a clamp meter. When the system is isolated (disconnected from main battery and running only on second battery) then everything is fine even at high volume. When it is connected through the main battery, it is dropping the voltage down for the whole truck. The whole thread about the issue is here:
https://www.diymobileaudio.com/threads/veh...ng.407221/
Also, I considered a second deep cycle battery with a split charger. However, I was advised that when the truck is started, it is the alternator supplying the power to the sound system anyways and that it wouldn't solve my problem. I only listen to the sound system with the truck started.
Post #550585 17th Apr 2020 12:44am
Jasdip
I have a 1 farad capacitor installed and swapped it with another one for testing. It didn't make any difference with the swap or with it removed altogether. Although just a couple of days ago I noticed that the capacitors both didn't appear to be holding any charge (they're pretty old). I thought that the second battery would have likely acted as a large capacitor anyways and that didn't help either.
I know that I need probably at least 3 farads, but again, the battery should have helped. I considered getting one of those 20 or 50 farad ones too but I thought I might just be wasting more money.
Someone was thinking to try an Super Capacitor for their set up as well who had a similar issue, I looked into it but I thought if I'm spending hundreds of dollars then why not just hit the root of the problem instead. This is the one:
https://www.amazon.ca/gp/product/B07T5CJNM...&psc=1
Post #550588 17th Apr 2020 1:08am
Jasdip
I've talked to various professionals over the past couple of years (on and off) and searched around on online forums while posting voltage and current test results, etc.
The audio professionals point back to checking grounds, replacing capacitor, add second battery, possibly replace the alternator. Land Rover says turn the music down because that draws too much power and voltage drops. Some people suggest the fuel pump or coils may be starved of power and therefore not injecting fuel properly (which I feel is the problem too); however, unless it is a bad part, the solution is still to fix the voltage drop. The voltage shouldn't be dropping to 12v or under anyways..
Post #550590 17th Apr 2020 1:18am
RR P38
Looks like you have found what you need then, its either a super cap or its a large bank of batteries, shortest possible cable runs will help too.
With the load you are drawing its intermittent, im guessing.........I would say there is no way the Voltage regulator in the alternator can account quickly enough, its most likely going to cook it, super cap is the best bet by the looks of it.
My home stereo system has a dedicated 20amp 220volt feed direct from the switch board for similar reasons to your issue, it works.
Post #550591 17th Apr 2020 2:24am
Jasdip
The only issue is that when I first got the truck new, for several years everything was fine. Doesn't make sense for me to need to install more batteries and capacitors now to get back to what I was at before. The factory alternator was replaced a few years ago too and battery was replaced about 2 years ago.
I never did (or needed to) any voltage tests to see what the main battery was at for voltage under heavy load when the truck was new and everything was fine.
Putting in this alternator won't be a cheap "test" either!
Post #550737 17th Apr 2020 10:55pm
RR P38
Do you have a multimeter? If you dont just buy a cheap one...........Check your charge voltage and more importantly the battery. If you are concerned at spending too much money this may save you replacing something that you dont need too.
Not using diagnostics this way you are just fumbling about in the dark
A battery at 2 years old going on 3, is probably at 60-70% of its new CCA with the sort of load you are placing on the system.
Contrary to what 95% of us believe alternators shouldnt be used to recharge dead flat batteries, sure they can do it but it is very taxing, thats why we have battery chargers.
If your battery is cactus I would be looking at getting a Lithium battery if I was you they can serve higher demand loads and last much longer than lead acid or calcium batteries.
If as you say everything was running fine for a while chances are the battery is screwed or the alternator voltage regulator is on the way out or your super cap.......or possibly a combination of all 3
This is a good option for you as well;
Post #550738 17th Apr 2020 11:17pm
