Home > Technical (L322) > Oil cooler gm auto box
Flocks
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
I had the dreaded bong of the transmission failsafe prog come up on my dash on Tuesday, and it appeared to only have 3rd gear. After searching on here i thought it was pointing to a blocked oil cooler, so today I took the oil cooler off and the pipes, the oil that came out was pretty clear red with no sludge or dirt in it. The oil seemed to be flowing out of it just fine.
The radiator and cooling system was all flushed and replaced with coolant about 4 months ago.
My question, is there a way of telling if the cooler blocked?
I’ve flushed the pipes through with fresh oil and it was coming out as clean as it was going in.
Many thanks in advance.
2004 vogue
Td6 5 speed auto gm box
200k miles
This type of oil cooler.
Also I can select low range and back with no problems.
Post #549913 10th Apr 2020 7:52pm
RRPhil
Although I admire your optimism, the failsafe message is not related to overheating transmission fluid. You’ve probably read that, if the transmission fluid is overheating, the transmission ECU selects its ‘cooling strategy’ mode which inhibits upshifts to keep the engine speed (and therefore flow through the cooler) high. This does not result in the failsafe message being displayed. I’m afraid your situation is more serious. I would suggest that you remove your sump pan and check for metallic debris.
Phil
Post #549958 11th Apr 2020 10:55am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Overheating of the transmission is usually first noticed when it goes into an overheat strategy. It will try to hold onto lower gears for longer which increases the input rpm to the transmission so turns the oil pump faster and pumps more fluid around the cooling system to help bring temperatures down. If it still can't bring the temperatures down then it might go into a failsafe mode.
There are many other reasons why you can get a trans failsafe and a code reader is the only way of knowing for sure why it popped up (some can be as simple as a low battery voltage).
So assuming it is a temperature problem, did you check the water coolant passages of the oil cooler as I suspect it's those that will give the most issue not the oil passages.
The oil cooler is just a heat exchanger which uses the bottom few sections of the main coolant radiator to dump it's heat. It's usually the bottom of the radiator that gets blocked as sediment settles over the years which in turn also might pass into the oil cooler.
When mine went into an initial transmission over heat strategy one summer I changed the radiator and oil cooler (radiator had very small leak anyway). I've never had a problem since, must have been over 5 years ago now.
I don't think any amount of flushing of the radiator, even if removed to do it, will effectively clear the bottom few sections of the radiator.
If you've had a new recent radiator then I would look at the oil cooler water coolant passages...again assuming the failsafe is from an over temperature event...200k miles on a GM transmission is good going if not already replaced.
Editted to add...I see RRPhil has replied while I was typing mine, he's expert on the RR transmissions around here so ignore me lol!
Post #549964 11th Apr 2020 11:04am
Flocks
Thanks for the reply.
I put it all back together this morning and topped the oil level back up. When I drove it it was changing gear as it should and then after about 3 miles ‘bong’ and we were back to what I’m sure is third gear, if I shifted across to manual mode I can down shift the 2 and then 1 and then back up but it won’t go past 3 although the dash says it’s in 4 and then 5.
Tomorrow I’ll pull the sump off and check it’s contents.
Phil if it is worst case and I need a new box can you recommend anyone in South Wales?
Post #550014 11th Apr 2020 6:43pm
RRPhil
Hopefully your problem isn’t as serious as this, but a well known issue with the 5L40-E is the failure of the direct clutch drum and shaft assembly (the so-called ‘toilet roll shaft’) which allows the transmission to operate in all gears except 4th & 5th (i.e. the two ratios that require the direct clutch to be engaged).
This shaft is manufactured by winding a piece of steel in the same fashion that cardboard is wound to make the centre tube of a toilet roll.
Anyway, hopefully your particular issue is simpler and cheaper to fix. I’m afraid I don’t do any work on the 5L40-E so I’m not aware of any good repair shops in South Wales but hopefully other forum members may be able to recommend someone.
Phil
Post #550029 11th Apr 2020 9:13pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine suffered the failure RRPhil says above:
Went with a hell of a bang while accelerating. Ended up with no drive in forward gears (just like a clutch slipping), and a horrible scraping noise in reverse. Oh and it actually said "Transmission Failure" on the dash, not the usual Trans Failsafe Prog. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #550333 14th Apr 2020 4:45pm
Flocks
I’ve taken my transmission out now, just trying to arrange a rebuild which is proving tricky in this current situation.
Is it a diy job? And which companies can supply the new parts that would be required?
Thanks guys
Post #550431 15th Apr 2020 7:53pm
RRPhil
https://xoutpost.com/bmw-sav-forums/x5-e53...rdown.html
http://www.vanmatic.com/pwpcontrol.php?pwpID=8356
https://www.sussexautos.co.uk/auto-parts.php
https://jpat.co.uk/index.html
Phil
Post #550456 15th Apr 2020 11:31pm
