Home > Maintenance & Mods (L405) > Spacers on the rear. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
if you have 21'' or 22'' the rears look ok...20'' not so much but spacers are for peeps with defenders and such.. ... - .- -.
6th Feb 2020 3:42pm |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
Stan. I’ve got some 22’s but they’re 9.5 wide. If memory serves me right standard turbines or the like are 8.5. I was thinking 25mm spacers just on the rear but I’ll try the wheels and see what they look like. |
6th Feb 2020 3:54pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3745 |
Turbines are 9.5”x22 with an offset of 49mm
6th Feb 2020 3:59pm |
you're correct ..the 20'' are 8.5j and the 21'' and 22'' are 9.5j so you get an extra inch on each side... ... - .- -.
6th Feb 2020 4:00pm |
Ah I stand corrected. |
6th Feb 2020 4:01pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1253 |
That extra inch makes all the difference........ |
6th Feb 2020 4:59pm |
You can almost get the same effect on 20” by fitting 285/50/20 tyres instead of the 255/55/20 as it’s not just the rim width but also the tyre width that makes the difference 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
6th Feb 2020 5:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
My 23" are considerably more offset than my SVO 22's (winter wheels)
6th Feb 2020 11:10pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Almost all aftermarket replicas are 45 offset compared to the stock 49. Running a 285/40/22 on a 45 offset wheel will make a very noticeable difference. I noticed it every summer on my l322 when I went from stock 20s 49et to my replica 22s on 285/40/22. That’s the widest/biggest combo you can go with no rubbing on the l322 and from what I’ve gathered is just about the widest safe for the l405 2014 FF Autobiography 5.0 SC
7th Feb 2020 3:15am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
I have some experience with Spacers on the L405, as you may know, I am a bit of an off road Junkie, and in my time owning the L405 I have had several wheel and tyre combinations to find the best compromise and on road/off road performance. Not only are wheel spacers in short supply for the L405, but you wont find any large spacers for the simple reason that there is not enough stud length for it to be safe beyond 5mm.. Hubcentric spacers are a rarity, and for me I have had some large 275 60 20 off road tyres on that required a 5mm spacer, but also tried 325 55 20 with the same spacers..
10th Apr 2020 6:14am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
Strikes me any of the options discussed in this thread would invalidate car insurance. Surely most insurance companies would not even consider such modifications for on road use. |
10th Apr 2020 8:35am |
