Home > General (L405) > Stolen...
Page 5 of 5 <12345
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
*diesel Dave* question if I may?, so the "original" OBD port just sits in a void behind where it was situated and the new dummy is reaffixed where the original was ie is there any major faffing to keep the original out the way? or is it just a 10 minute job ?
Thanks
Maccaa Current FF Westminster 4.4 V8
Post #579545 13th Jan 2021 9:01am
diesel Dave
Hi Maccaa. Only a 10 min job to be honest, I just tucked mine out of the way then popped the new once in the slot. You could go to greater lengths and clip it higher up but I don’t see the point, just want to put any would be thief off if they plug in.
I tried plugging my diagnostic reader in and it gives it power, but will not communicate with any ECU’s.
Post #579661 13th Jan 2021 9:27pm
Maccaa
thanks diesel Dave I appreciate the response, I will get one ordered Thumbs Up Current FF Westminster 4.4 V8
Post #579728 14th Jan 2021 12:36pm
Phil.
Went to fit mine today and the OBD port is missing! I could see an unused square (ish) connector which I assume should have the OBD connected?
It’s a MY19 and had its first service on the 4th Jan 21. I was told it had a software update. Nothing was mentioned about the OBD port missing. Should I be concerned?
I suppose at least the thieving scum can’t connect to the OBD port. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #579867 15th Jan 2021 2:50pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I think they might move things around but for obvious reasons these things aren’t shared or encouraged to be discussed here.
Post #579927 15th Jan 2021 10:12pm
my thoughts exactly..
phil, if you do find yours it would make sense not to mention where it is located on the forum..... ... - .- -.
Post #579928 15th Jan 2021 10:14pm
Phil.
Thanks both for the reassurance. I’m not going looking for the port, it can stay lost.
I have other security features fitted anyway, so this was just an additional layer which is redundant in my case. MY23 D350 HSE
Post #580092 17th Jan 2021 10:58am
I wonder if now they have lots of connectivity in the cars whether LR has some Bluetooth diagnostics they connect with so the OBD becomes redundant....? There is nothing that can't be fixed with a hammer😜😜
Post #580111 17th Jan 2021 1:22pm
Page 5 of 5 <12345
