Home > In Car Electronics (L322) > Changing Language
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Changing Language
My FF was originally in the French speaking part of Switzerland at home. Therefore the language is set to French.
I can switch it to my native language German but every time I disconnect the battery or make some changes with the IID Tool all switches back to French. Big Cry
Is there a way to change language for good? Without seeing the stealer?
Post #548099 24th Mar 2020 9:27am
i've looked through the GAP menu for yours and there doesnt seem to be any language settings ,
but , for the very few times you will disconnect the battery and make an adjustment with the IIDTOOL , i wouldnt worry to much..
its only a few clicks to get your language.. ... - .- -.
Post #548100 24th Mar 2020 9:43am
Ansi
You'r right Stan, I just wondered if I have overseen some features in the menu. At least I'm not competely lost when French comes up. Whistle
Post #548114 24th Mar 2020 11:30am
Weegie
I think you can't change it as you want. I believe the default language would be set for the market it was sold in and every time you disconnect the battery it defaults.
As Stan says, how often do you disconnect the battery? John
GAP iiD BT
Post #548123 24th Mar 2020 12:30pm
