| 120 k on the miles I have a new alternator to go on and belts etc , just need to investigate the manifold temperature sensor? As mentioned earlier, also need to check out the turbo drain mod if it’s been done already ( is there an easy way of checking?) as I don’t know the history of the car I’m somewhat in the dark as I bought this as a damaged repairable cat N the is no marker on log book as it was non structural, only faults were bumper, crash bar , bumper cameras, parking sensors not working due to severed loom on crash bar (easy fix ) and alternator fault .
was running when I bought it No problem apart from the alternator not charging so wouldn’t run for long until it started shutting down so I guess this is why the insurance wrote it off
 So I need to sort everything in the front area of the engine before putting everything back 1990 3.5 v8 defender
 2000 4.6 v8 30th anniversary prins lpg
 2004 4.4 v8 vogue  prins lpg
 2011 4.4 TDV8 Vogue
 faultmate extreme
 rsw allcoms
 Autel 906BT
 Gap iiD tool
