Home > In Car Electronics (L322) > Radio sound prblem
BIRDY57
United Kingdom 2006 Range Rover Vogue Td6 Rimini Red
Radio sound prblem
Hi guys, hope someone can point me in the right direction with this. A couple of days ago whilst driving, my radio sound went off. The head unit is still picking up stations. The CD still changes and shows the tracks are playing. Just no sound. Can anyone say if this has happened to them and what do I look for and where is it situated. Cheers all.
Post #547314 16th Mar 2020 1:06pm
mjdronfield
Have a look for water ingress in the left hand site cubbyhole in the boot. The amps etc are in there.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #547330 16th Mar 2020 3:49pm
BIRDY57
Hi and thanks for the reply. I,ve had a look right down to the bottom of the space where the units are mounted and all looks dry.
Post #547339 16th Mar 2020 5:37pm
SilverParrot
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Check all the contacts for signs of corrosion, furry deposits or damage.
Post #547818 21st Mar 2020 1:07pm
BIRDY57
Hi Everyone. I posted this thread back in March of this year when the audio system on my 2006 L322 decided to stop working. Everything looked like it was working on the touch screen (change channel on radio, play and change CD, satnav navigating) but there was no sound from anything.
Checked all the usual - plugs for security and cleanliness, damp, etc - but all was ok.
After" going round in circles" I took the plunge and bought a used amp from fleabay. The original took a bit of time to remove as it sits right at the bottom of the rear well. Fitted the replacement temporarily to see if it worked, and lo and behold got sounds back in the fatty!
If this helps fine but if you do decide to buy from EBay, don't put "Range Rover" before your search, only put in the mpdel number number. I say this because the amp I sourced is also fitted to Discovery's of the same age.
The one I bought was from a Discovery and it fitted straight in, and no need to interface with the car itself, just plug and play.
Happy Days! Very Happy Very Happy Thumbs Up
Post #565175 22nd Aug 2020 1:13pm
