Home > Technical (L405) > Front air suspension re-levelling after starting
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
When the car is left in normal height and parked - is it normal for the front suspension to rise slightly occasionally after starting the car or does this indicate a leak? I’m wondering whether the car is just re levelling itself or if pressure is lost and then recharge when the car is started? Grateful for any guidance before I add to the list of warranty jobs! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #547047 13th Mar 2020 9:32pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Where you park is it level or does it dip down slightly? If it has a slight dip the suspension maybe finding it's level when you start up, you could park the other way round and see if the front still lifts. Also, not very scientific I know but you could measure the gap between tyre and wheel arch when you park and check again next time you go to the car and see if it's dropped.
Post #547066 14th Mar 2020 8:04am
Jase71
I think the surfaces are pretty level and would not have thought the amount of height change would be needed to correct. Most of the Time the car is Set to auto access height but if I turn it off and leave the car at normal height, you see the front height minor correction when starting. 2017 Range Rover Vogue V6 Diesel
Post #547072 14th Mar 2020 8:26am
Jase71
Something I don’t notice when the car is in auto access height 2017 Range Rover Vogue V6 Diesel
Post #547269 15th Mar 2020 9:55pm
mine has occasionally done this when parked on an uneven surface...i reckon its self leveling.. ... - .- -.
Post #547286 16th Mar 2020 6:56am
Jase71
thanks Stan. I think I'll turn on auto access height again and then I won't need to worry Laughing 2017 Range Rover Vogue V6 Diesel
Post #547298 16th Mar 2020 9:32am
CS
Rising a bit on start-up is normal as far as I am concerned, I've never worried about it. I asked for auto access height to be turned off as I don't need it and it's just adding to the "work" the car has to do so it might wear out sooner (?). Only Range Rovers since 1988
Post #547320 16th Mar 2020 12:45pm
you say that you 'asked' for the auto access height to be turned off, did you know that its selectable in the drivers menu... ... - .- -.
Post #547323 16th Mar 2020 1:13pm
CS
You are quite right, what I did was to ask the dealer to turn it off at handover as I knew it would default to that and I didn't want to have to work out how to switch it off. Only Range Rovers since 1988
Post #547325 16th Mar 2020 2:06pm
Thumbs Up ... - .- -.
Post #547326 16th Mar 2020 2:15pm
Crasher242
Mine does the same - and mainly happens at home as our widened driveway has a distinct slope and dip Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #547528 18th Mar 2020 2:12pm
