Home > Technical (L405) > Front Door card removal
supershuttle
I have an issue with my front door card (nearside) it seems that despite me fully popping home the pop studs it comes loose from the bottom. Not a big issue but irritating nonetheless, so today I set about removing the door card using the Powerful video as my guide. All went well but with all the screws out and poppers and clips released it wouldn't come away far enough to allow me to disconnect the door lock cable - has anyone else had this problem. I just put it all back together with a screw missing as I dropped one inside the door and as I couldn't get the card off couldn't retrieve it. Any insights anyone? Geoff
Post #546321 7th Mar 2020 5:41pm
David405
United Kingdom 2013 Range Rover Vogue SE TDV6 Barolo Black
I had to remove my drivers door card a few months back to replace the winder motor and I seem to remember that there is an electrical connection (near the front lower side?) that needs to be disconnected to allow a bit more play. 2013 405 TDV6 Vogue SE Barolo Black
2007 L322 TDV8 Vogue (Gone)
Post #546323 7th Mar 2020 6:23pm
