Home > Technical (L322) > Single oily injector
DMRR
Hi all,
Just been checking under my engine cover (was off to check hoses) and one of the injectors seems to be oily (black) in comparison with the others.
There are no symptoms ... is it just one of those things?
If you look at it from the drivers side it is no 2 from the bulkhead...... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #545889 3rd Mar 2020 2:22pm
ShuntL322
United Kingdom 2002 Range Rover HSE Td6 Zambezi Silver
Probably either leaking at the copper washer were it sears in the head. Or the fuel pipe to it.
If it’s dark most likely the copper washer at the base. Not too hard to change.
Copper rings are a couple of pound from your local injector specialist.
Post #546043 4th Mar 2020 10:23pm
